Refresh Rate Help Plz!
Go to solution Solved by o0Martin,
It's 60Hz @ 1080p
I am thinking of buying the Acer S231HL from someone for 60 bucks and I can't find the refresh rate for the monitor. What is the refresh rate @ 1080p?
CPU: i5 4690 GPU: Powercolor R9 390 RAM: 2X4GB DDR3-1600 G.Skill Ripjaws X Case: NZXT S340 Motherboard: Gigabyte GA-H97-D3H CPU Cooler: Some cooler I took off of an old Socket 775 Mobo
https://linustechtips.com/topic/450159-refresh-rate-help-plz/
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/450159-refresh-rate-help-plz/#findComment-6035331
The default is 60Hz. It ranges depending on certain settings and resolutions(like for example, if the resolution is set to a lower setting, you can increase the refresh rate from 60Hz to 75Hz).
https://linustechtips.com/topic/450159-refresh-rate-help-plz/#findComment-6035410
It's 60Hz @ 1080p
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
https://linustechtips.com/topic/450159-refresh-rate-help-plz/#findComment-6035461
Where are you getting 75Hz from?  :mellow:
https://linustechtips.com/topic/450159-refresh-rate-help-plz/#findComment-6035510
specs page. vertical refresh rate, 50-75
Rigs I've Built
https://linustechtips.com/topic/450159-refresh-rate-help-plz/#findComment-6035524
Lol the scan range? That's a little bit different.
The monitor out of the box will be running at 60Hz @ 1080p. It's a 60Hz refresh rate monitor.
Although using the vertical and horizontal scanning rate on that spec page you can kind of calculate the max refresh rate if you were to overclock it, it comes out to about 73Hz.
Those specifications aren't really that useful to most people now a days, they were a lot more useful when everyone was using CRT displays
https://linustechtips.com/topic/450159-refresh-rate-help-plz/#findComment-6035579
