Hi guys I need some suggestions for 120mm fans that I can buy in new Zealand. This is for the air 540 corsair case and I need 3 good cheap ones for airflow. Any suggestions?
CPU: Intel i7 8700k || Motherboard: Asus Z370-E ROG || RAMCorsair 4266 2x8gb || GPU: Sapphire r9 280x tri-x || Case: Corsair 780t ||
Storage: Samsung 850 Evo 250GB, 1TB Segate Barracuda HDD || PSUSeasonic M12II Evo 850w || Display: AOC i2367FH 1920x1080p 23 Inch ||
CPU Cooler: Corsair h80 || KeyboardCorsair Strafe || MouseCorsair Scimitar || HeadsetHyper X Cloud II || OS: Windows 10 ||
https://linustechtips.com/topic/449636-case-fan/
Budget? Do you care about silence? or static pressure? Would they be used for a radiator?
More specific plz.
Also, follow your topics.
"I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party."
-Ron White
https://linustechtips.com/topic/449636-case-fan/#findComment-6028417
budget for the cost of all three? in new zealand or american dollars please. :3
any colour preferences? LED?
follow your topics. ^_^ill be on PCPP immediatly and try to help the best i can.
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
https://linustechtips.com/topic/449636-case-fan/#findComment-6028435
hello? ;~;
-Jim Hensen
https://linustechtips.com/topic/449636-case-fan/#findComment-6028497
Hi sorry for late reply, if there is colour, blue or red, don't mind if there's no led. New Zealand dollars as well too :)
There is no real budget just need best bang for buck fans. Need for airflow
https://linustechtips.com/topic/449636-case-fan/#findComment-6028643
More specific plz.
Hi I need them for airflow, just to intake air. No radiator so no need for speed fans. Preferably not too loud
https://linustechtips.com/topic/449636-case-fan/#findComment-6028651
https://linustechtips.com/topic/449636-case-fan/#findComment-6028706
Lost the thread xD so I made a new one sorry.
https://linustechtips.com/topic/449636-case-fan/#findComment-6028715
You can find your threads and post in 'Find Content' on your profile.
Locking thread.
https://linustechtips.com/topic/449636-case-fan/#findComment-6028717
Guest
