Onboard sound replacement?
Hi Guys,
My motherboard is the Z87-HD3, and i realised how crap the onboard sound is! Even the amp/dac on my Moto G 2nd gen is better!
Can someone find me a replacement? At a reasonable price? Under £40.
I have the Edirol FA-101. and am thinking of getting a pci firewire card for it, would that be a good option? Or should i get something else?
If someone could suggest a decent pair of speakers for a similar price, overall good sounding, but i like a fair bit of bass.
That would be great!
Thanks
Gershy13
CPU: Ryzen 7 5800x + H150i Elite LCD
RAM: 32GB Corsair Vengeance Pro RGB DDR4 3600MHz CL16
Motherboard: Gigabyte X570 Aorus Pro
GPU: MSI RTX 3070 Ventus 3X OC
SSD 1: Corsair MP600 1tb (Windows)
SSD 2: Samsung 840 EVO 120gb (Scratch Drive)
SSD 3: Samsung 860 EVO 250gb
HDD 1: WD Blue 1TB
HDD 2: Seagate Barracuda 2TB
Case: NZXT H710
PSU: Corsair TX750M
Mouse: Lamzu Atlantis Pro Mini 4khz
Keyboard: Akko 5075B Plus
OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/449225-onboard-sound-replacement/
Hi Guys,
Thanks
Gershy13
Do you have the Realtek Drivers for your Audio?
Yup
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
Yup
Hmm. Do you use front ports or the rear ports? For the front ports did you connect the HD Audio or AC97?
I have my speakers plugged in to the back ports, but when I try my earphones (Xiaomi Piston 2) I plug em in at the front. I'm not sure about HD audio or ac97
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
Where do you plug in your earphones?
To the front panel headphone port on my Zalman Z3
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
I would get better speakers.
Really? What about the earphones? That's what I mainly use
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
£40 budget?
http://www.amazon.co.uk/Audio-Technica-ATH-M20X-Professional-Headphones-Black/dp/B00HVLUR18/ref=sr_1_3?ie=UTF8&qid=1442162459&sr=8-3&keywords=audio+technica
Audio Technica ATH-20X
Update you bios.
How would that help? Also how do I do it?
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
I thought the Xiaomi pistons are pretty good?
How bad is your audio. In what way?
Tbh I know a bit about audio, so I wouldn't know. I know those Audio Technica are good because I've use them before.
My phone sounds clearer, playing the same song, and if i try and use an eq on the pc, pushing the 31hz band, does nothing, but on the phone, it has an effect
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
It's helped some people with these problems before. As for how, this is a tech forum, I'm sure there are threads about it, or a video from our Deer Lord, Linus.
hmm, ill try
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
Is it 3rd part software or the windows one? the eq?
its the realtek one.
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
This one?
This one?
Similar...
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
Similar...
I would Update the drivers as well as the audio manager. That could be the problem
ok, ill try
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
Both are up to date
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
Both are up to date
Get a firewire card for your Edirol FA-101 then or get and external DAC
