hi guys, im looking for a cheap 5.25inch fan controller because my pc is just loud. any recomendations? i prefer one between 20-35 bucks. thx
CPU: i7-2600 @ 3.4 ghz  l  Motherboard: ms-7728 l  RAM: 2x4GB Kingston HyperX DDR3 1866MHz  l  GPU: GTX760  l  Case: Phanteks enthoo pro  l  Storage: 250GB crucial bx100 ssd, 500GB Seagate pipeline hdd  l  PSU: EVGA SuperNova 750 G2  l  Displays: iiyama Prolite E2208HDD, HannStar JC199D  l  Cooling: AVC 92mm downdraft l  Keyboard: P.O.S. keyboard that came with pc in Jan. 2011 l Mouse: Maxxter gaming mouse   Sound: On-Board   Operating System: Windows 10 Pro  l
https://linustechtips.com/topic/449029-fan-control/
If you want cheap, and don't mind ghetto rigging it....A dimmer switch....In essence it's a variable rheostat. It takes whatever voltage is coming in, and decreases it by a set amount depending on the position of the knob....Not ellegant, but it does work, and it's the cheapest way I know to get a fan controller.
https://linustechtips.com/topic/449029-fan-control/#findComment-6020764
i love ghetto riggin but it's a show pc so i can't but still, thanks for the idea
https://linustechtips.com/topic/449029-fan-control/#findComment-6020802
Even with appearance being important, the guts of the system can be invisible, with just the metal poking out, at which point you can put whatever you want on it to turn it. (A plus for case modders) as @ThatOneRussian stated, there are options however.
https://linustechtips.com/topic/449029-fan-control/#findComment-6020808
