cheap silent fan
Go to solution Solved by Rusty_Shackleford,
http://amzn.com/B000O8I474
four pack of 120mm cooler master fans for less than 15 bucks
I second this post. This is a good deal if you're short on cash.
hello, its gigabiter. my pc is kinda loud :( and i dont have much money to blow on $80 fans that are loud as hell
im only ten and i got $100 and 4 fans in my case at the moment so TYPE AWAY
SPECS
GPU:Msi r9 270x. PSU:corsair CX600M. CPU AMD-fx 8320. CASE: ultra etorQe mid tower. HDD:1tb barracuda.MOTHERBOARD:ASUS M5A97.
https://linustechtips.com/topic/448334-cheap-silent-fan/
also follow your posts so you can see other's replies
https://linustechtips.com/topic/448334-cheap-silent-fan/#findComment-6012002
you can get four cooler master fans for the price of one corsair lol
I'm a corsair fanboy >_>
CPU: I7 4790k  CPU Cooler: NH-D15 GPUMSI 970 4gb   Motherboard: z97 Gaming 5 PSU: Corsair hx850   Ram: Corsair Vengeance 8 gb  SSD: Samsung 850 Evo  Case: Air 540
https://linustechtips.com/topic/448334-cheap-silent-fan/#findComment-6012024
I am a cheap FANboy.
I have antec Twocool fans in my PC because I got them for an amazing price of 3 bucks per fan and they have two speeds without bodging cables. 5 of them to be exact. Pretty darn quiet!
https://linustechtips.com/topic/448334-cheap-silent-fan/#findComment-6012035
https://linustechtips.com/topic/448334-cheap-silent-fan/#findComment-6012039
It would help to mention what kind of dollars you're using, your current specs, and which parts are loud.
https://linustechtips.com/topic/448334-cheap-silent-fan/#findComment-6012073
I remember him saying he has a 270x and FX8. Not exactly sure on everything else.
Cougar Vortex fans can be quite good for a low amount of money.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/448334-cheap-silent-fan/#findComment-6012201
