Hello there
I have a i7 4790k and i had it for little over a month.
it worked amazing but now for some reason it won't go over 10% usage no matter what i do.
I like to play CS:GO and i get like 40 fps now an i usually get 300 fps steady.
When i check on resource monitor then the CPU doesn't go over 10% on all cores.
any suggestions would help.
thank you   :)
Mys specs:
MSI Z97 Gaming 5 motherboard
i7 4790k
MSI GTX 980
G.Skill 2133mhz 4x4gb
Crucial 500 gb ssd
https://linustechtips.com/topic/447943-cpu-problem/
What is your GPU usage!
I don't think the GPU is a problem...
Silly question, is your monitor plugged into your motherboard?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/447943-cpu-problem/#findComment-6006163
My monitor is plugged into the GPU
Go into bios, Are you in powersaver mode?
https://linustechtips.com/topic/447943-cpu-problem/#findComment-6006195
