FIrst off, I will apologize for poor grammar. I am typing this from a phone and sacrifices will be made.
So basically, I was playing a game and a ton of artifacting began. I closed the game and it continued to my desktop. I reset my pc and it remained, so I reinstalled my gpu drivers by going into device manager, uninstalling, and then running my installer to put them back, with no drivers I had no artifacting, but once back to normal gpu use it was there. i also know its not the wires or monitors, since i also have 2 monitors with two separate video inputs i know that it is neither cable nor monitor.
My temps are cool when it happens as well (48c), my gpu is a sapphire vapor-x manufacture of the Amd r9 270x platform and my gpu is just a couple of months over a year old.
So I ask, is there anything else to check before concluding 100% that it is hardware, did i not reinstall my drivers right? might it be not even gpu related? i want to. conclude by tomorrow, as i am in need of my pc for quite a few things right now and will simply express ship a 970ti if it being broken hardware is the case
edit: starting to get a horrible hunch it might be mobo, the artifacts only happen when something is active on screen
https://linustechtips.com/topic/447825-artifacting-help/
What is your computer build? If your getting artifacting it could be due to a damaged core or a bad overclock. WHAT is your Overclock MHZ, Any extra voltage? What motherboard? Age of your card is around 1.25 years? did you ever have high heat, VRM heat? Asic Quality?
https://linustechtips.com/topic/447825-artifacting-help/#findComment-6004429
i hate phones, had accidentally submitted an unfinished post when you had replied. however i can say as far as i know my gpu temps have never went critically high, even on the highest end games i play i was checking temps a week or so ago and they didnt go above 65-70c
the motherboard is some gigabyte thing which is the same age as the gpu, will edit when i find it
edit: ga-h81 with an i5-4670 8 gb of ram and a 2 tb 7200rpm hdd is what i remember, i could probably dig out my old build list and receipts and id every part but that is off the top of my head save the mobo
https://linustechtips.com/topic/447825-artifacting-help/#findComment-6004451
well artifacting appears when the gpu is clocked to high (unstable oc). sometimes a driver update destroys an oc due to changed power limits or other changes.
the question is if your gpu is oc'd over the advertised clock speed. if it is than you know what to do. if its not you just got bad luck in the silicon lottery and sapphire's quality control was made with different drivers.
if this is the case send it back to sapphire and ask for a new one
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/447825-artifacting-help/#findComment-6009484
It's not overclocked and it's a year and a half old. So unfortunately both of those are not valid to me.
https://linustechtips.com/topic/447825-artifacting-help/#findComment-6010175
mhm on some cards you have two year warranty.
but try clock it down under the normal clock speed. perhaps try to raise power limits so that the card gets stable. if that doesn't work im out of ideas
https://linustechtips.com/topic/447825-artifacting-help/#findComment-6012628
Yeah i tried both things but neither worked, its alright i suppose since i ordered a GTX 970 from newegg yesterday. Time for an upgrade I guess.
https://linustechtips.com/topic/447825-artifacting-help/#findComment-6018430
