I'm hoping a few of the members here are knowledgeable in car audio :D
I'm wondering how I would go about installing two single din head units (Stereo and Pop-Out Cup Holder) into one Double Din Slot.
Can I just use a Double Din Fascia, or would I need a split fascia with slots for two separate head units.
For reference I will be installing in a Vauxhall Astra H, so if someone could point me in the direction or where to buy the correct fascia that would be great.
https://linustechtips.com/topic/447631-car-audio-question/
I think u should split
Edited by Benielishackove
When i'm not playing PC games i'm playing with my PC parts  Fans,Pumps,Filters,  :wub:  :wub:  :wub:
https://linustechtips.com/topic/447631-car-audio-question/#findComment-6002054
You can normally fit two 1 DIN items into one 2 DIN slot. I'd prefer to have a split fascia however, as the mounting may be more solid (unless you have screw mounts on the frame).
https://linustechtips.com/topic/447631-car-audio-question/#findComment-6002935
