Hi everybody,
First of all, Here my PC Spec:
Seasonic M12II 750W EVO - 80 Plus Bronze Full Modular (new purchase)
E3-1231v3 @3.4GHz
DDR3 8GB
Gigabyte B85m-D3H
Palit GTX 970 Jetstream / Driver 355.82 (new purchase)
and..... 1366 x 768 monitor *so shame, don't have enough budget to upgrade it*
The problem is: some games's performances are really bad, like CS:GO, Max low setting with multi-core rendering ON, can only have 100~150 fps.
Please check my spec if I'm doing anything wrong with it and give me advices to improve my PC performance.
Many thanks.
https://linustechtips.com/topic/447494-please-troubleshoot-my-spec-problem/
do you have DSR on ?
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
Try turn your grahical settings up as high as possible. Even then with such a low resolution the CPU will be worked a lot more harder than the GPU.
Failing that try use DSR and up your res to 1080/1440 to give more load to your GPU
CPU: i7 8700k   Motherboard: Asus Maximus Hero  RAM: 16GB @ 3600Mhz  GPU: MSI 980Ti 6G  Case: Fractal Design R5 (4 Intakes/3Exhausts)  Storage: Crucial BX100 SSD, Samsung 850 & Seagate 2TB HDD  PSU: Seasonic M12II Evo '850W'  CPU Cooling: Corsair H110i GT
I just turn to max setting with DSR 1440p and the GPU still load at max 20%, CPU max 33%, fps ~130. :(
