My first pc build cable management is crap but happy with it so far
Has
Core i5 4690
16gb of Kingston ddr3 ram (note only 8 installed when photos taken)
Gtx580
Deep cool cpu cooler
Tqo segate 1tb drives
One Kingston 128gb ssd
Corsair vs650 powersupply
Asus DVD drive l
Gigabyte ga h97 h3 motherboard
And is in a zalman z9 case
All opinions are wellcome
https://linustechtips.com/topic/447335-first-build-solo-build/
You could've done a better job with cable management. The case doesn't seem like the best out there, but there must be a way to tuck the unused PSU cables behind the motherboard plate for example.
The fan on the top (the one that is clearly visible) - does it blow air in? If yes, I'd turn it around and look for a way to fit an intake fan below or in front of the HDDs.
Crosshair VIII Dark Hero | 5900X | NH-U14S | Asus X Noctua RTX 3070 | MP600 | 850 EVO 250 GB | Caviar Black 5 TB | SS-860 XP2 | Define R5 Black | Thaulab Varna IV -> Objective 2 -> Sennheiser HD-555/AKG K7XX/Audiotechnica ATH-M40x
https://linustechtips.com/topic/447335-first-build-solo-build/#findComment-5997077
yeah with a case with a side panel having cables looking like that is a shame, spend a few minutes get yourself some wire ties and push a smuch of that junk behind the mobo as you can
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/447335-first-build-solo-build/#findComment-5997082
The case was cheap this was built on a budget theres a 120mm fan blowing through the front and another exhausting out the rear plus one blowing Down on the cpu cooler and graphics card
https://linustechtips.com/topic/447335-first-build-solo-build/#findComment-5997116
Nice, good Job for the first time. But you have to redo your cablemanagement. The way it is now, it will hinder the airflow.
Just take your time and it will look better too ;)
Example of my PC. Not a single cable in the way.
http://imgur.com/20A4QCB
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/447335-first-build-solo-build/#findComment-5997176
