My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/44693-fan-screws-6-32/#findComment-586624
I already saw that before, and I don't want a screw, I want a nut
Then change the title?
https://linustechtips.com/topic/44693-fan-screws-6-32/#findComment-604467
Maybe you should read the post and not only the title
I scan through posts and I'm 95% sure your post had nothing to do with 'nut'.
https://linustechtips.com/topic/44693-fan-screws-6-32/#findComment-604493
And what means the 6-32 from my screw?
It designates the size of the screw. The 6 means #6 standard size screw. The 32 is the thread spacing, means there's 32 threads per inch so you need a nut that matches the same spacing. Also, 6-32 is the same size screw that holds your HDD's.
His first post said "I bought two fans for my side panel, but I need a specific nut to hold it.".
https://linustechtips.com/topic/44693-fan-screws-6-32/#findComment-604505
Honestly, I don't care.. His title says 'screw'. His post says 'nut'. Is it my fault he has both? No.
https://linustechtips.com/topic/44693-fan-screws-6-32/#findComment-604539
Here is a photo of the instructions that came with my case: http://i.imgur.com/u5kwvOa.jpg
I must find a nut with the same reference, right?
https://linustechtips.com/topic/44693-fan-screws-6-32/#findComment-604541
Thank you for your help, but with the shipping fees to my country, the total price is a bit expensive for what brings on it.
I will keep searching for other stores
https://linustechtips.com/topic/44693-fan-screws-6-32/#findComment-605681
