I have build my 1st pc but after putting everything done, cable in power on. Gpu fan cpu fan rear fan front fan moving. Mobo led have light. Nth is showing on monitor and no sound or anything. What happening?
Can you please give us specs? What LED is on the motherboard? My asus board has 3 or so LEDS one is a cpu error, the other a ram error and one is a power led. If this is an intel board with onboard graphics then plug your monitor into that then in bios set your display to the GPU.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/446918-need-help/#findComment-5990796
