So the GPU is at STOCK. NO OVERCLOCK and the Nvidia driver stops responding every time. I will post a pic below but i need help.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/44617-stabilityburn-in-problem/
What are you running for burning in?
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585299
What card are you using? Does it have a factory overclock and what are you using as a burn in test?
MSI 660ti PE OC, yes it has a small factory OC, Furmark
Furmark
| F@H STATS |
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585304
Do you have any games that you can try perhaps? It's also possible that the factory OC is unstable.
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585310
Yeah games run fine on Max settings, there not intensive but there on max and work fine
| F@H STATS |
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585312
Do a clean install of the 314.22 drivers and try again. http://www.nvidia.co.uk/object/win8-win7-winvista-64bit-314.22-whql-driver-uk.html
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585313
Furmark
Furmark is not really recommended for NVidia card, since the drivers will give up because of some burning issues NVidia had with Furmark and the 4xx series of cards. Run a graphically intensive game insted and see if it happens
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585315
Whats the best program?
| F@H STATS |
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585316
I always recommend games like Far Cry 3, Crysis 3, Metro: Last Light, Metro 2033 or The Witcher 2
Edit: Any 3DMark can also be used, but I recommend you let it loop for atleast 2 hours
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585321
You can try using Kombustor for stress testing programs. You can also try using the Valley or Heaven benchmark.
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585323
Thanks I'll try
| F@H STATS |
https://linustechtips.com/topic/44617-stabilityburn-in-problem/#findComment-585744
