If your PC uses one of those smaller portable adapter-like PSUs - then a new PSU would be the first thing you need. the CPU is decent and the RAM is enough.
https://linustechtips.com/topic/445944-help/#findComment-5976904
dont bet on it.
he wouldnt be able to install it, that'd require a new case, and new mobo, if you have bad luck the cpu is soldered on.
https://linustechtips.com/topic/445944-help/#findComment-5976912
dont bet on it.
Oh - right. Forgot how pre-builts work :/
https://linustechtips.com/topic/445944-help/#findComment-5976921
I'm looking through the vents, I don't see any like psu slots for the motherboard lie the 24 pin one. FUCK did I get the wrong PC? I just got this pc
well... if you just got it, and are now planning upgrades. you just did it the wrong way.
https://linustechtips.com/topic/445944-help/#findComment-5976949
Nvm got a full refund
What is your budget?
My PC:
MOBO: MSI B450 Tomahawk Max, CPU: AMD Ryzen 5 3600, Cooler: BeQuiet! Dark Rock 3, GPU: Gigabyte GTX 1050ti D5 4G, Ram: 16GB (2x8) HyperX Fury DDR4, Case: NZXT S340, Psu: Be Quiet! Pure Power 11 600W , HDD's: WD 1TB Caviar Blue, WD 256GB Scorpio Blue, WD 2TB Caviar Blue  SSD: Sandisk SSD PLUS 240Gb
https://linustechtips.com/topic/445944-help/#findComment-6017381
