So I have a Corsair H75 that I will be using in my build but I'm not sure if the case that I'm planning on getting will fit it. I'm looking at getting this one on new egg (Thermaltake H21 Versa).
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133247&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
It looks like there might not be much room above the CPU to mount the rad. If this won't work do you guys know of another case that will in that price range?
Here is the rest of my build in case you're interested. http://pcpartpicker.com/p/xYzWqs
https://linustechtips.com/topic/445736-will-my-cpu-cooler-fit/
It won't fit if the H75 is 140mm
Edit: H75 is 120mm it's fine
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/445736-will-my-cpu-cooler-fit/#findComment-5973912
