Nothing all the cables will be provided.
<p>CPU: AMD FX-8320 @ 4.0 GHz | GPU: Asus GTX 970 STRIX | RAM: 8GB (2x4GB) Corsair Vengeance LP 1600MHz | Motherboard: Gigabyte GA-970A-UD3P ATX | SSD: Samsung 840 EVO 500GB (Boot Drive) | HDD: 500GB | Case: Corsair SPEC-02 Red |PSU: Corsair 750W | OS: Windows 7 64-Bit | Mouse: Corsair M65 (Black) | Keyboard: Corsair K95 RGB (Black w/ Brown Switches)
https://linustechtips.com/topic/445642-help-with-cable/#findComment-5972474
Unless you are overclocking you don't need to do anything in your bios, except select what drive to boot from.
https://linustechtips.com/topic/445642-help-with-cable/#findComment-5972480
Like, others have already said the manufacturer's of the products normally provide a bunch of cables. Whether or not you want to buy custom sleeved cables is up to you.
"Have you tried turning it off and on again?"
Code of Conduct ■ Suggestions ■ Report a Bug ■ FAQ with Windspeed36 ■ Useful Links ■ Memes
https://linustechtips.com/topic/445642-help-with-cable/#findComment-5972615
why do you have a water cooler for a computer that CAN NOT overclock?
The overkill factor. ;).
https://linustechtips.com/topic/445642-help-with-cable/#findComment-5972624
normally cable is with what product together? mobo? PSU? and the HDD power cable will be with the PSU?
https://linustechtips.com/topic/445642-help-with-cable/#findComment-5972680
The motherboard normally comes with SATA cables so that you can connect hard drives to it so that data can be sent and received. The Hard Drive power cable will come with the power supply.
https://linustechtips.com/topic/445642-help-with-cable/#findComment-5972683
Heck I didn't need a H60 for my A10 7850K but I bought it as it made the inside of the system nice and neat. On top of that the cpu fan doesn't ramp up to a million miles an hour trying to cool the thing under load. I don't blame this guy for getting the water cooler. Quiet and clean.
https://linustechtips.com/topic/445642-help-with-cable/#findComment-5973487
