virtual box question
if i have a scammer use teamviewer or whatever can he get access off that to my normal computer? thanks!
The "motherboard" and OS used via VM are different. However you might want to do some network trickery (simple VPN works) so that he can't do crazy things with every device on your network).
https://linustechtips.com/topic/445341-virtual-box-question/#findComment-5967715
