Hi guys
When playing witcher 3 my frames drop for 60 to 48 ish and causes stutter ,
However my house never exceed 80 percent when this happens and there's a small cup spike from 40 percent usage to 60,
If I stay in the area where the grams drop after about ten seconds they go up to 60
Is this the game? Sli issues ?
Do I need to overclock my cpu ?
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/445213-witcher-3-frame-drops/
SLI can cause all sorts of funky stuff. Try with 1 card.
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966142
Temp Issue maybe
Temps are good top card is at 79c and gpu never down clocks
And one card isn't enough for 4k
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966151
Lower the res - might be VRAM issues - 4K isn't really okay with 4GB
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966156
980tis 6gb and I have a few settings down so I should be ok on the vram
It's installed on my hdd maby that ?
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966164
Lower some of the settings like foliage distance and shadows perhaps, they impact performance a lot.
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966169
Try with 1 card.
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966174
already done that it's really strange Ty for the tips tho
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966175
Turn hairworks off - that really kills performance.
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966185
Try with 1 card.
One card I can play at 1440p 60 fps no problems
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966188
You could try this go into your control panel and manage 3d settings, global settings and change this setting:
it was suggested when arkham knight was performaning like poop worth a shot or checking some of those settings to see if there is any more AA being added on top of what is already been done by the game itself.
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966198
Hair works off
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966200
Ok il try this Ty
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966207
Hair works off
Hmm - set everything to low and try 1 card.
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966213
Works ok on low but I don't wanna play on low lol
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966224
Low still looks good honestly ^_^
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966249
Il try it but I spent a grand on sli 980ti's :( I'm sure il sort it out tho
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966261
4K isn't really an option for Ultra 60fps, sorry man :/
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966273
I'm not maxing the game I have msaa off
Ssao
Shadows are medium foliage distance is medium
The question is why does the gram rate drop if good are not at 100 percent
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966324
Ssao
Well - not sure. Could be SLI - try rolling back drivers or updating them.
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966345
Seems all good now with the cards set to prefer Max performance
also (1600)
https://linustechtips.com/topic/445213-witcher-3-frame-drops/#findComment-5966352
