weird restart and start
Solved by Dellmor,
If you have a spare PSU plug it in and try it, if it's a lower wattage just dont plug in into your GPU and run the post on on-board graphics.
Try a different PSU if possible - the B series are decent but nothing to write home about.
oh my gosh u guys I fixed it and you wouldn't believe what was causing it, not the psu, not the cables, all that is ok. the freking setting in BIOS, CPU FREAKING UNLOCK, I remembered I did unlock it couple days before starting this thread. So I disabled it and everything is ok now, but I cant overclock my cpu tho. But thank you guys for suggestions and willingness
