So my iPad 1 will only charge on its 10w adapter. When I try to use my computer or a built in USB like a USB outlet it won't charge. Does it need a certain wattage. It's also jailbroken could that cause it. I never noticed if it did it before so don't ask.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/44492-ipad-1-charge-problem/
Some motherboards such as Asus have a feature which will provide enough power to the Ipad/IPhone. The feature is called AI Charger +
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/44492-ipad-1-charge-problem/#findComment-583521
Hello
Kull Stalder, Mac pro user...
It is charging it just takes a long time to charge compared to your 10v charger
about 62% more time to be exact
#KilledMyWife
LTT's Resident Black Star
I should get an award for still being here at this point
https://linustechtips.com/topic/44492-ipad-1-charge-problem/#findComment-583532
