This is my first build I have posted many topics about parts lists and all of it has changed. My final build consists of an amd a8 7650k, 8gb of ram, 2 gtx 670 4gb, Msi a88x-g45 motherboard, a Wd black 1tb hard drive, a cooler master 650m, all in a corsair spec-02. Got all my parts from Fry's electronics and the 2 670s from a craigslist guy. In total it all costed around $850.
https://linustechtips.com/topic/444854-first-pc-build/
Why did you get an APU if you bought a dual 670's? You could've gotten a FX-6300/6350 or an i3-4160 for the same budget basically in terms of the CPU
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/444854-first-pc-build/#findComment-5961749
Wouldn't this be posted in Build Logs?
*ahem*.. mods...
Still a nice looking build. You did what you could to hide those absolutely horrid-looking cables. I also like how you chose a mobo that hides all of the traces and doesn't have any random obtrusive colours. However, I don't understand the choice of an APU if you had bought 2 external GPUs. You could have gotten a much more powerful CPU for the same price.
"I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party."
-Ron White
https://linustechtips.com/topic/444854-first-pc-build/#findComment-5961852
Why didn't you go with Intel i5? Its more expensive but very reliable. I wish I could afford one tho
PC Specs   - Black and White Build
    Intel Core i5 4690k MSI Z97S Krait LGA 1150
    Crucial Ballistix Sport 1x8GB 1600MHZ
    Sapphire Radeon R9 270 (Will be upgrading this soon)
    EVGA 500W PSU
    Phanteks Enthoo Pro - White
https://linustechtips.com/topic/444854-first-pc-build/#findComment-5961862
no ssd?
ssd isnt a Necessary part of a system
it is an upgrade/luxury item, not a absolute mandatory thing for a pc
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/444854-first-pc-build/#findComment-5961984
