Hi everyone i'm currently planning on building a new pc and here are some things i'd to state beforehand:
Budget: $2200
Items already owned: mouse, monitor and OS
Usage: Gaming and school work (solidworks,Catia...)
Heres what ive come up with: http://ca.pcpartpicker.com/p/vxpYFT
Also im not sure if i want to go with a x99 chipset or the z97 let me know which is a better choice. Thanks
https://linustechtips.com/topic/444751-pc-build-help/
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($139.75 @ Vuugo)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  ($184.98 @ Newegg Canada)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  ($155.98 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($129.75 @ shopRBC)
Video Card: MSI GeForce GTX 980 4GB Video Card  ($661.98 @ Newegg Canada)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($93.00 @ Vuugo)
Total: $2075.29
Generated by PCPartPicker 2015-09-05 18:22 EDT-0400
Okay, heres the Canadia dollar build
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5960344
I recommend going this way:
You get a way better 980Ti for the cost of overclocking your CPU, with this 4 cores/8 threads Xeon you don't need any OC anyway.
CPU: Intel Xeon E3-1241 V3 3.5GHz Quad-Core Processor  ($339.99 @ Amazon Canada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.98 @ NCIX)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($158.98 @ Newegg Canada)
Memory: Mushkin Redline 16GB (2 x 8GB) DDR3-2133 Memory  ($128.98 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.98 @ DirectCanada)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($909.98 @ Amazon Canada)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($149.99 @ Memory Express)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($144.98 @ Newegg Canada)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard  ($147.98 @ Newegg Canada)
Total: $2200.59
Generated by PCPartPicker 2015-09-05 18:23 EDT-0400
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5960362
Budget: $2200
On X99, quad channel memory kits are optimal (4 memory modules).
But I think Z170 would be a better platform. The higher clock rate of the i7-6700K will provide much better performance gaming, in most of Catia, and Solidworks.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($469.99 @ Memory Express)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($34.99 @ DirectCanada)
Motherboard: Asus Z170-P ATX LGA1151 Motherboard  ($166.25 @ Vuugo)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($142.77 @ DirectCanada)
Storage: Samsung SM951 256GB M.2-2280 Solid State Drive  ($289.99 @ Amazon Canada)
Video Card: EVGA GeForce GTX 980 4GB FTW ACX 2.0 Video Card  ($660.99 @ Newegg Canada)
Case: Fractal Design FD-CA-CORE-3500-BL-W ATX Mid Tower Case  ($112.50 @ Vuugo)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.93 @ DirectCanada)
Total: $2195.37
Generated by PCPartPicker 2015-09-05 19:40 EDT-0400
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5960856
Total: $2195.37
Thanks so much for this build plan! Just one question why is this chipset cheaper than the x99?
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5965029
Skylake is only a 4 core cpu. The X99 platform cpu's are 6 core and 8 core.
If your CAD software can make use of the extra cores then the 5820K will be the better choice. Otherwise the Skylake build (Or even Z97 i7/Xeon) is a cheaper option.
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5965265
ah that makes sense. so which chipset do you think will benefit me when using cad programs?
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5965296
I can't answer that as I don't have any knowledge of CAD software.
You might be better going on the Catia and Solidworks forums, or someone on here might have knowledge of that particular software.
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5965629
  1. if you go with the 5820k, you need a better cpu cooling solution. get the h100i gtx from corsair or the noctua nh-d14
the motherboard you chose is very expensive. you can get away with a less expensive board from msi
i would get an 850 evo from samsung for the ssd
you can easily squeeze a 980 ti in there if you get an i7-6700k or an i7-4790k or if you got a cheaper case
other than that, looks good
BigDay
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5966489
It really depends on the workflow. Catia and Solidworks mostly use one or two cores. But there are functions such as rendering that can use more.
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5970022
  2. the motherboard you chose is very expensive. you can get away with a less expensive board from msi
  3. i would get an 850 evo from samsung for the ssd
  4. you can easily squeeze a 980 ti in there if you get an i7-6700k or an i7-4790k or if you got a cheaper case
  5. other than that, looks good
about the msi mobo, i never used anything from msi so i dont have a great deal of knowledge on it so what would be the major diff bettween an asus board and a msi board?
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5970217
depends on the board offered by both vendors. they are both quality manufacturers. i would pick either one.
BigDay
https://linustechtips.com/topic/444751-pc-build-help/#findComment-5970550
