Will this work good for a security system?
i just need to know if this will work ok
http://www.newegg.co...N82E16881147039
 http://www.newegg.co...82E16822178393
needs:
Night vision
Motion detection
on 24\7
under $300
4 of them
THAT MOMENT YOU DISASSEMBLE YOUR COMPUTER....AND REASSEMBLE IT ....JUST SO SENPAI WILL NOTICE YOU
https://linustechtips.com/topic/444210-will-this-work-good-for-a-security-system/
Can't speak to the quality or value of the surveillance system (Security is alarms and notification), but WD Purple drives are designed for this purpose. Might be a better idea than the Seagate NAS drives.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
are they 24/7 drives? i plan on using this all the time...not recording all the time, but vieweing all the time ,and recording when necessary
"WD Purple Surveillance Storage is built for 24/7, always-on, high-definition surveillance security systems that use up to eight hard drives and up to 32 cameras."
So yes.
@Captain_WD might be a better person to ask about them.
WD Purples are designed for continuous use (specifically for multiple video feed recording).
Unless the Seagate NAS drives are datacenter quality they won't be rated for continuous use.
ok, can you link me to a WD purple you would recommend? [under $150]
Stretch your budget $10 and you can have the 4TB model
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236659
otherwise 3TB model
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236660
