Cross-Flow or standard rad
Solved by SonoDanshi,
It depends entirely on how you want your tubing to look. x-flows can be useful for avoiding very long runs of pipe across components. Performance wise there is a very tiny (margin of error) difference between x-flow and u-flow rads of equivalent specs so it will really come down to convenience.
There is a partial discussion on the performance of x-flow vs u-flow in the thread below and contains a video of someone benching the 2 rads for comparison.
http://linustechtips.com/main/topic/443591-radiator-port-help/
