help building a new pc
Go to solution Solved by HumbleMobo,
hey guys i'm kinda new to the whole forum thing from linus but i've been a subscriber for a long time and i have finally decided that after learning more and more about pcs and fixxing them i decided its time to build my own mid-high range pc build.... with a gtx 970 and an i7 4790k how could i go wrong? the motherboard.... i want my entire pc to be built around a blue theme i alrdy picked up a case (the corsair 500r with some blue LED fans) and a set of ram 4x4 configuration clocked at 1866 mghz  from gskill and most of my other parts picked out i only had 1 thing left to do and that is pick out my motherboard... this is a real problem for me at the moment i did find a really nice looking mobo from asrock the extreme 6 lga 1150 z97 chipset i thought this was an easy pickup then i read some reviews on it.... alot of complaints about the usb ports and the device software not working with it... i need some feedback on if this board actually has problems with all that stuff and if it does then i need some suggestions on a board .... my price range is about 180$ and i only have 2 requirements.... i need it to be blue and i need it to be a z97 chipset.... other then that the range is open if yall can help that would be grand thankyou
Actually of the ones I showed you , this is the best MOBO it is for 189.99$ but this one is awesome!
http://www.amazon.com/MSI-DDR3-Motherboards-Z97-G55-SLI/dp/B00K23BVXU/ref=sr_1_99?s=electronics&ie=UTF8&qid=1441363270&sr=1-99&keywords=lga+1150+motherboard
https://linustechtips.com/topic/443756-help-building-a-new-pc/
Blue motherboards are really hard to find but if you want a real good mobo with all the features you need then here you go!
http://www.amazon.com/MSI-Motherboards-Z97-PC-MATE/dp/B00K23BW70/ref=sr_1_4?s=electronics&ie=UTF8&qid=1441362877&sr=1-4&keywords=lga+1150+motherboard
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947386
by the way i didnt know if i needed to specify this or not cuz i thought it'd be obvious but ram is ddr3
You can go for MSI's MoBo's from their "Normal" lineup they have blue ones their PC MATE model is a typical choice
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947389
Here's a fancier version of the first board I showed you
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947392
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947399
that one is actually pretty damn nice i might just go over budget for that one really great option i didnt even know msi made blue mobos
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947407
Yep that's because you were probably looking at their "Gaming" Mobos
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947411
This motherboard Is incredibly friggin tough and it is probably best in class in terms of military grade components in MSI's lineup.  Plus it's SLI ready so you'll be good to go with a couple 970's up in there!
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947419
haha definitely man i'm glad i came to the forums for this i didnt know people would respond so quickly
xD that was my first reaction I was like "Holy shet!  People respond like lightning!"
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947421
i definitely planned on getting a 2nd 970 in the future or passing the 970 that i'm getting onto my uncle and picking up a 980ti but thats for the future when i get a 1440p display monitor ;)
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947425
2 tips to surviving this forum, One: ALWAYS follow your topics so that you will be instantly notified of a post, Two:  When you get your answer press mark solved beneath the forum post.  Lol it's like 6:00 AM here...I'd say that's obsessive
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947432
Please tell me you're getting a Ben-Q gaming monitor!  They are pretty cheap right now.
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947440
the problem i think i have with gaming monitors is the colors.... yes they look great but with the gaming monitors they do sacrifice a little bit on the visual for things like faster response times and refresh rate bla bla bla.... i'm never goign to be that good at games lmfao so until i see a ben-q gaming monitor that looks as good as an LED monitor from someone like asus then i'll probably avoid them ig i just prefer the visuals as the gaming expierience vs the actual performance? if that makes sense... unless theres a monitor that ben-q makes that i dont know abotu (which is entirely possible)
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947456
Since we dont know your budget, here is an example.
Also 390>970, and  the 4790k supports dual channel, it is better to have 2*8 gb modules than 4x4
Blue theme
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($317.99 @ SuperBiiz)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($57.99 @ Newegg)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard  ($96.98 @ Newegg)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-2400 Memory  ($79.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($98.98 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($314.98 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ NCIX US)
Total: $1116.39
Generated by PCPartPicker 2015-09-04 06:57 EDT-0400
The site has changed....
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947459
Blue theme
Total: $1116.39
Question already solved, he only wanted to find a different motherboard didn't you read?  And he didn't want an ASRock one
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947468
Also 390>970, and since the 4790k supports dual channel, it is better to have 2*8 gb modules than 4x4
Blue theme
Total: $1116.39
lol my budget is around 1500ish... but like i said i arldy picked up the memory and the case.... and as far as GPU goes... i'm sorry but there is no way i'm ever going to touch AMD gpus not with a 10 ft pole haha i'm straight nvidia they have always been my BAE
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947470
fanboy spotted :P
Tbh, no, cause not all answers were loaded when i posted. lel
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947489
Actually Ben-Q monitors are very good now, they also have a new mode where when your playing like an FPS which usually have dark maps it will make the map brighter somehow and you will be able to see into shadows where enemies may be!  In my opinion it's a game changer!
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947491
i will definitely have to check it out then thanks for your help man but i'm going to bed cuz i gotta work in 4 hours ... ugh but you seem like a cool dude maybe we could game together sometime haha just msg me
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947498
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487075
here is your best GPU option It has the fastest clock speed but won't make that much of a difference and it has blue accents as well as a sexy back plate
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947508
ahha yeah maybe a little bit of a fanboy but with pretty good reason
If you're like me and you like the long ones(insert lulz here) then get the Gigabyte windforce which also have a back plate!
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947515
I think both of those cards, if you act now come with Metal Gear Solid V: The Phantom Pain
https://linustechtips.com/topic/443756-help-building-a-new-pc/#findComment-5947520
