I've been experiencing random screen blackouts lately. It just turns black and then comes back after around 5-10 seconds and happens even when I'm not doing anything. The monitor doesn't seem to lose detection since no usual prompt pops up. Any application I'm using, or video I'm watching just continues running while this happens too.
This only started happening since I started using DisplayPort instead of DVI for my BenQ XL2420T monitor. I misplaced the DVI cable that came with it and had a very difficult time finding a DVI Dual Link cable that let me run 120hz. I opted to try DisplayPort instead and bought one from a local store. The DisplayPort cable's brand is CableMatters. 120hz works perfectly using this cable, but then the screen blackouts started happening.
I was wondering if anyone else has experienced this and believes it's because of DisplayPort. I really don't want to hunt for cables again, and the particular DisplayPort cable I purchased was pretty pricey as well. But I'd be much happier knowing the cable was the only issue than if it were my CPU, GPU, PSU, MoBo, or anything else.
Thanks!
My specs are:
Monitor: BenQ XL2420T 120hz
CPU: Intel Core i7 3770k 3.5GHz OC to 4.2GHz
SSD: Samsung 850 EVO for OS
Motherboard: ASRock Z77 Extreme4
Video Card: MSI GeForce GTX 970
RAM: 16GB G.Skill 1600
https://linustechtips.com/topic/443606-help-random-screen-blackouts/
Thanks!
My specs are:
Do you get notifications that the video driver has stopped responding and has recovered? Just wondering.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
