Hey im in the middle of planning my first watercooling loop. I want to do a mat/pastel blue fluid in the loop (prob naming it the Big Blueberry or something like that). I was thinking about using Mayhems Pastel Coolant in blue. Does anyone know if its good to run for months on end without having to buy more and then refill the loop? Meaning long term use? Also idk how much im going to be needing. Right Now im planning on 2L of it to fill the loop but idk if its too much or not enough.
http://www.performance-pcs.com/mayhems-pastel-coolant-1-liter-blue-berry.html
Consume The Darkness
https://linustechtips.com/topic/443197-water-cooling-fluid/
People generally say to just get coloured tubing and use normal distilled water you avoid getting gunk stuck in the loop and avoiding any blockages
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/443197-water-cooling-fluid/#findComment-5939774
Do they sell pastel blue hardline? I havnt seen any colors for it
http://www.performance-pcs.com/water-tubing-soft-hard/shopby/color--blue/
Not really a watercooling expert but here's blue tubing
        Setup
https://linustechtips.com/topic/443197-water-cooling-fluid/#findComment-5939924
Im looking specifically for a pastel blue color like the Mayhems. I havnt found any Hardline Tubing in blue except for translucent and thats not the color im looking to get.
https://linustechtips.com/topic/443197-water-cooling-fluid/#findComment-5939944
Sorry I couldn't be of help
        Setup
https://linustechtips.com/topic/443197-water-cooling-fluid/#findComment-5939980
