My PSU making high pitch noise. It is as loud as normal talking. 1st time hearing it was in the morning while i turning off my fan. After unplugged it about 10 minutes then plug it in again the sound was gone. 2nd time hearing is that evening while browsing web. This time a tried unplug and plugged, it is still there. But after unplug it for a while, like 10 minutes as in the morning. And it gone.
Is it normal coil whine? Or my PSU is drying. I bought it just 2 day ago.
i7-4790k (4.0 GHz no oc)
MSI Z97 gaming 5 Motherboard
MSI GTX980ti
ADATA SSD SP920 128Gb
ADATA SSD SP920 256Gb
Thermaltake Toughpower Grand 1050W Platinum.
This is my 1st Build and 1st post. So i'm sorry if it's bad.
https://linustechtips.com/topic/442747-psu-making-sound-sometime/
eww that power supply
Yeah, it's an El Cheapo power supply, get something of quality.
Welcome to the Fourms!
That PSU isn't the best, as for the high pitched noise it's most likely coil whine which is normal it can happen sometimes and can't be avoided.
Toughpower units are decent if you ask me - not really a cheap one. Well, not as cheap as other TT stuff :D
Coil whine - it happens - not dangerous.
Return the PSU as defective and get an EVGA Supernova G2 650 or 750. With that gpu without overclocking the cpu and without sli you don't need more.
My Build:
CPU: i7 4770k GPU: GTX 780 Direct CUII Motherboard: Asus Maximus VI Hero SSD: 840 EVO 250GB HDD: 2xSeagate 2 TB PSU: EVGA Supernova G2 650W
He literally bought it a couple of days ago, so eh...
From my experience TT are rather prone to coil whine - first my TT Smart SE, now his Toughpower - I guess they do skimp out on the glue adhesive.
lol
Yes at least it's not no name brand ticking time bomb kind of PSU.  :D
or like the CX series :P
Grade to hear that it's just a coil whine. Guess i'm gonna live with it for now. Need to save money for coming oculus rift :)
Yes, i'm plan to sli later.
Thanks for helps, guys :D
