What type power supply do people use for a Small NAS BOX
If it's a NAS chassis (like the Netgear ones), they have integrated power supplies, you just insert the hard disks. Job done.
For a NAS like LTT in their compact NAS video, a 500W would probably do the job.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/442673-power-supply-for-nas/#findComment-5932981
Like brand
and type like Corsairs AX or RM Series
https://linustechtips.com/topic/442673-power-supply-for-nas/#findComment-5933067
Like brand
Depends how big.
If you can fit an ATX PSU, an EVGA 550GS/G2 are great for their price range (with the GS being a little smaller).
I don't know much about SFX PSUs, but the Seasonic ones look alright. I'd have a look at them.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/442673-power-supply-for-nas/#findComment-5933570
Depends how big.
I have decided to use the one he had in his vid.
https://linustechtips.com/topic/442673-power-supply-for-nas/#findComment-5933589
