Need Help Overclocking GPU And CPU
Solved by Mikjul,
With the mild overclock the system is no long bottlenecked. (Noticed massive FPS's jumps went from 30-35 FPS , To 60+).
So in laymens terms with the crappy motherboard any GPU OC i do will not affect FPS or performance?
It is entirely up to you, but you will see MASSIVE gains from the new intel system in comparison to the gains with your AMD one.
