First Build Gaming/Streaming/Editing
Solved by SeanAngelo,
Okay thank you, I'll save myself some money and go the 5820 and EVGA 980 ti superclocked 2.0 then. Just one more question. If I decide at some point to go dual sli will 850W be enough and am I better off buying a 980 ti reference card?
edit: Also, above when I asked about multi-tasking what I mean was running multiple programs at once.
850W will be enough. The 5820k will handle that easily. And don't get the reference, get the EVGA like you mentioned.
