Best solution for consistent fast boot ups
Go to solution Solved by MG2R,
Hey just to be double sure, since boot up speed and snappy response in windows is based on random read/writes and not sequential, doesn't the Vertex 4 kill the 840 Pro? It has an unparalleled random write of 120 000...!?
Making purchase this week, just wanna be double sure!
Can't give you a definitive answer on that. My experience is: once you have an SSD, the difference between different SSDs is far less noticeable than the difference it makes going from HDD to SSD. Most of the time, I just pick the cheapest SSD from a reliable manufacterer. In my case that turned out to be Kinston V200+ a number of times.
Just have gotten my girlfriend a regular 840 and that is plenty fast as well.
Because of the bad rep on OCZ, I'd  pick Samsung in your case. That said, OCZ's more recent SSDs use in-house controllers, with which I do not have experience, so I can't comment on those.
I have a 120Gb Samsung 840 now, i would like to be able to boot up as fast as a fresh installation of windows on a new SSD. Should i get a 840 Pro 256Gb for OS+softwares and some games or i should use a 840 Pro 256Gb for OS+important softwares and the 120Gb for games?
Open to other ideas too, thank peeps!
https://linustechtips.com/topic/44238-best-solution-for-consistent-fast-boot-ups/
SSDs don't work like mechanical drives, you can have 1mb free and it will still be as fast as if you just installed windows. I've been using the same SSD for over a year and it still boots up just as fast as the first time.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
Pretty much this^
Also, the pro is marginally faster than the regular 840.
You won't be able to tell the difference.
*So long as it has TRIM, which the 840 does.
PC Specs: i7 4770k @ 4.3Ghz 1.165v, Corsair H100i + 2x SP120 PE in Pull, Asus ROG Maximus VII Hero, 8GB Kingston Hyper-X Genesis 1600mhz, X-fire Sapphire HD7950 3GB OC Dual X Edition, Sound Blaster X-Fi Titanium - Fatal1ty, 60GB OCZ Agility 3, 120GB OCZ Agility 3, 480GB Seagate 600 Series, 1TB WD Caviar Black, Corsair TX850, CM Storm Trooper, Win 7 Pro. Peripherals: Microsoft Sidewinder X6 Keyboard, Logitech G700S Mouse, Sennheiser G4ME ONE Headset, Logitech Z-5500 5.1 Speakers. Phone: HTC One M8.
The less applications it has to load at first the better I guess. Put your computer to sleep during the day if you know you will use it later and turn off over night?
erm, i used the Vertex 4, 840 Pro 128Gb and 840 120Gb. they all have the same results.
first boot(fresh installation of windows) is hella fast. after installing my stuff on it(left abt 40'ish gigs). it boots up much slower than before..=/
i want something that can boot up super fast and consistent over time.
would having 2 SSD's do the job?
2 ssd in raid 0 will help, but the problem you are talking about (that the boot is slower after installing a lot of application) has nothing to do with your ssd.
A computer once beat me at chess, but it was no match for me at kick boxing
A fresh install would be quicker as it only has to load windows.
Once you install something that requires a startup process, whether it be on an SSD or HDD it will slow down your boot. Even a custom desktop background will slow it down slightly.
I don't think another SSD would completely solve it, as you could be saturating the SATA interface.
exactly, i'm trying to think of solutions =P
okay so raid 0 is one.
but 128Gb 840 Pro in raid means abt 1Gb read and 600mb write speeds.
compared to 1 256Gb 840 Pro which has 540/520mb speeds..
any other ideas maybe?
or 1 250Gb 840 SSD for OS+software?
i'm guessing the reason why my SSD slowed down so quickly is because i have filled it up past the half-way mark. like i've used 80Gb out of 120Gb..
The less stuff your pc has in the start up folder the better, so if you have skype and razercomms and steam,orgin all this stuff starting up when you start up your pc, than its going to be slow as shit!
how to install them somwhere else when some softwares can only be installed in the C drive =C
If you can afford it buy a new 120 gb 840 and make a raid 0. Install ALL os and programs in this raid.
Install games on a HDD or buy a the new 840 evo for the games
hmm reason being?
hmm reason being?
Well you have a 120 gb 840 now and you want to make a raid0. That's why another 120gb 840. Don't let the read and write speed guide your choice to much. Read and Write are the least important in a SSD.
To be able to start windows and programs fast, you will need to have the os and all programs installed on that Raid0.
That's why " Install ALL os and programs in this raid"
Games also benefits from an SSD, but not as much as os and programs. Games are a lot sequential read and a HDD is not that bad at that.
That's why "Install games on a HDD or buy a the new 840 evo for the games"
So basically it'd be good for me to have 2X 128Gb 840 Pro's in raid 0..?
I personally would buy a new 250 gb 840 evo and have that for os and programs. The current 120gb I would use for games. The HDD for movies, pictures, music, data etc.
But if you want the fastest boot time and the snappiest feeling in Windows you need raid 0, so then you should get one more 120 GB 840, not 2x 128 gb 840pro.
Regardless of your choice, be careful of what you install on your windows. Only install programs you need. Every program will make your computer a little bit slower
Hmm why not 840 Pro 128Gb in raid 0? Is that not faster..? :P
2 reasons.
First: you already have one 120 gb 840. Cheaper to buy 1 more 840 instead of 2 840 pro for the Raid 0
Second: Even if the 840 pro is a little bit faster, you will not notice that. The pro is just to expensive to make sense for a consumer.  It is more for enterprise use. Able to run hard 24/7. As a consumer you will not do that.
2 reasons.
Second: Even if the 840 pro is a little bit faster, you will not notice that. The pro is just to expensive to make sense for a consumer. It is more for enterprise use. Able to run hard 24/7. As a consumer you will do that.
Good points, last query, would u advocate a single 255Gb 840 Pro for now, then later another 256Gb 840 Pro, cos I will be going Japan and they already sell the 840 Evo. But I'd like to pick up a 840 256Gb in Japan and raid it xD
Btw, do u see any benefits to install win8? I'm thinking of Dx11.1 being native to win8 only =\
Sorry for the plethora of questions!
To be safe it is best to raid 2 identical drives. So 2 120 gb or 2 256 GB Pro etc. Don't mix them.
I don't know exactly what you mean, so i give some general advice
1. Use the same model and size then doing a raid 0
2. 840 is a great SSD, 840 pro even better but not worth the extra money for a consumer
3. 840 evo is replacing the 840 and are a little better.
4. Don't know witch of the 840 pro and 840 evo is the fastest, but the 840 evo is cheaper
As for Windows 8. It is personal if you like it (I DON´T). For gaming it is about the same as Windows 7
Let me tell you this: the reason Windows boots slower is because you load it with garbage applications that need to load on boot. RAID0ing your SSD with another won't make a difference. I'm using two SSDs in RAID0 right now, and let me tell you: it was a mistake. It doesn't do a whole lot to your boot time and because the RAID controller now has to initialise, my POST times are like 3 seconds longer.
What you should do is disable startup applications.
In Windows 8:
  • Open task manager
  • Go to tab start-up
  • Right click on anything you don't need to load on start-up (basically almost everything) and click 'disable'
In any older version of Windows:
  • Press ctrl+R
  • type in msconfig
  • Press OK
  • Go to startup
  • Disablie anything you don't need at boot
In Windows 8:
  • Open task manager
  • Press ctrl+R
  • type in msconfig
  • Press OK
  • Go to startup
i already did that before i posted. i can't think of other solutions hence i made this thread. i only have 8 applications that run on start, none of which are garbage for that matter.
and by ur logic, i'm guessing i should buy a a drive such that i would never cross the half way mark. like a 256Gb and not use more than 128Gb; since filling up SSD's slow it down.
cheers.
