R9 380 - MSI or Sapphire Nitro
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927925
/thread :)
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927930
I want to buy the best graphics card under $230 us. I dont care the brand or model just those raw fps.
GTX 960. This was pretty much the reason they made it: its a dialed down 970 for people who don't want to spend $350 for a graphics card
CPU: i7-4790k @ 4.4GHz | GPU: Gigabyte GTX 970 Gaming | PSU: Corsair CX600M | Cooler: NZXT Kraken x41 | Motherboard: Asus z97-E | Case: Zalman Z11 Neo | RAM: 16GB G.Skill Ripjaws X @ 2400MHz | Storage: 3TB Seagate HDD, 120GB Team Dark SSD |  OS: Windows 10 Pro
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927931
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927932
380 is about 10% faster than a 960 and is quite a bit newer than a 280X offering better longevity and better support for both DX12 and features such as Audio over HDMI, bridgless CF and Free-sync - things not available on the Tahiti chipset.
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927946
he said raw fps, not features. read the op
and 280x supports dx12, all 700 seires gpus do
supports over hdmi audi
and freesync.
Rigs I've Built
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927958
I am reading the OP - and as soon as a game uses a moderate amount of tessellation the 280X drops 20 frames while the 380 drops 8 frames - newer technology - it also uses better texture compression making the 4 GB on it quite a bit better tham the 3 GB on the 280X
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927974
benchmarks? and look at my post again
Rigs I've Built
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927985
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5927991
Tnx don ill use that to help me in deciding between the 280x and 380, although arent they both based off the same gpu?
280x is Tahiti from 2011 December. 380 is Tonga from 2014 - much newer and better tech integrated.
https://linustechtips.com/topic/442292-help-finding-gpu/#findComment-5928019
