I'm helping build a computer for a friend, and I could really use some advice on which specs to look at for a video editing and gaming computer. I know Processor is important, but which aspects impact smooth game performance and quick video rendering time are unknown to me. what should I look at, spec-wise?
https://linustechtips.com/topic/442283-editing-build-help/
What is your friends budget? I have a bunch of pre-designed gaming / video editing builds.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/442283-editing-build-help/#findComment-5927811
Well if gaming and editing video are his main focus then you're going to want to go for an i5-4460 and a GTX 970. Here's an example build.
http://pcpartpicker.com/p/WpsPBm <----- That's about as good as you're going to get towards the top of that budget.
https://linustechtips.com/topic/442283-editing-build-help/#findComment-5927848
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($232.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($64.80 @ SuperBiiz)
Video Card: MSI Radeon R9 380 4GB Video Card  ($229.98 @ SuperBiiz)
Case: NZXT S340 (White) ATX Mid Tower Case  ($62.10 @ SuperBiiz)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($46.80 @ SuperBiiz)
Total: $798.64
Generated by PCPartPicker 2015-09-01 22:07 EDT-0400
https://linustechtips.com/topic/442283-editing-build-help/#findComment-5927859
Total: $798.64
There's no reason to put a SSD in a build this small, the money saved could go towards getting a better GPU.
https://linustechtips.com/topic/442283-editing-build-help/#findComment-5927871
Why do you NEED a server case? It's gonna end up costing you a lot more, resulting in less performance else where.
https://linustechtips.com/topic/442283-editing-build-help/#findComment-5927965
gotta save what space we can. four gamers in 600 some-odd square feet is cramped to say the least. also, server chassis being my insistence means it's not gonna be considered in her budget.
You can always move your system into a server rack down the road, however it's better the focus the money towards performance now.
https://linustechtips.com/topic/442283-editing-build-help/#findComment-5928023
