Mobile GPU Problem
Solved by XthHaseo,
Yeah I have the CLEVO P150EM / SAGER NP9150 (Early 2012) 15.6-inch and I just found a site that sells everything for all laptops on Eurocom finally. The GTX 970M is an available upgrade for my specific computer so I think I've found it. Thank you for your input though Emanuel_M, no need to be nasty, my reply was for the others that replied here saying that usually GPUs are soldered on, and yes in most cases they are, but gaming laptops are a different thing entirely.
