Hello,
  So, in my car I have two 3-way speaker boxes. Soon I am gong off to college and am going to be taking them out of my car and putting them into my dorm room. I am looking for a two channel receiver that is capable of pushing around 200 watts per channel and has Bluetooth and HDMI inputs on it. Any suggestions would be great, thanks!
CPU: Intel Xeon E3-1231v3 XX Motherboard: ASRock Fatal1ty H97 Killer XX RAM: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1600 Memory XX GPU: Asus GeForce GTX 780 3GB DirectCU II XX Case: Phanteks Evolve ATX XX Storage: Kingston SSDNow V300 120GB SSD ; Western Digital Caviar Blue 1TB HDD; Western Digital Caviar Blue 3TB HDD XX PSU: Thermaltake SMART 550W 80+ Bronze
https://linustechtips.com/topic/442134-2-channel-stereo-receiver/
Car speakers are tuned differently from home speakers. You may have to EQ them differently for in-room use (or play with the enclosure).
Chances are your car speakers are rated 4 ohm nominal, so you may want to look around for an amp with a stiff power supply. It might actually be cheaper to buy a new set of home speakers and match them with a cheaper home amplifier than to look for a home stereo receiver that's well suited for your car speakers (sufficient current capacity and some EQ capability).
