hi guys, iv been away for a week came back turned on pc and when gaming i have a weird screeching noise, i ran a cpu stress test to eliminate that as a factor and it was quiet,
but when i do something graphically intensive it sounds likje how dial up internet used to sound.
i have also used msi afterburner to run fans at full speed to see it it was the fans and its not, i dont no what it is can someone help me please
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/441453-screaching-noise/
its probably coilwhine from ur gpu
what is coil whine i thought that was only on refferance cards ?
also (1600)
https://linustechtips.com/topic/441453-screaching-noise/#findComment-5916958
What are the temps under load?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/441453-screaching-noise/#findComment-5916963
Nothing like that.
More about Coil Whine here:
https://linustechtips.com/topic/441453-screaching-noise/#findComment-5916972
cpu 45, gpu 70 tops
also (1600)
https://linustechtips.com/topic/441453-screaching-noise/#findComment-5916973
cpu 45, gpu 70 tops
Alright!
Can you get your ear near the case and check where the sound is coming from?
https://linustechtips.com/topic/441453-screaching-noise/#findComment-5916994
omg thats it, is that bad for my gpu ?
i didnt think that could happen on none refferance cards?
is there a way to stop it ?
also (1600)
https://linustechtips.com/topic/441453-screaching-noise/#findComment-5917011
This may be stupid, But try Vsync ON and try it.
Just try it.
https://linustechtips.com/topic/441453-screaching-noise/#findComment-5917051
My started coil whining after 2 months and ever since then it's been on and off.
https://linustechtips.com/topic/441453-screaching-noise/#findComment-5917462
