I'm trying to set up a self hosted vpn (pptp) so that i can run splashtop where ever i want to rather than having to be on the same lan. I can go as far as to set it up on my windows 7 64-bit machine (make a new incoming connection, create a new user to connect through, port-forward port 1723, etc.) and i am able to connect with my android device successfully through its 3g connection. However where the problems start to occur is when i try to access the internet on my phone (droid x if that matters). It says that I'm connected through 3g and successfully connected through the vpn to my computer, but if i go to my browser or any internet application on my phone nothing will load. Ive tried google-ing solutions and havent found anything to fix this problem so I'm hoping that the forum can. And by the way I'm grandfathered into an unlimited data plan so please don't tell me that it will chow my data because i don't care.
https://linustechtips.com/topic/44137-vpn-problems/
You typically need a spilt access solution - so that data destined for the LAN gets sent over the VPN and all other data is sent out through your provider internet access.
I have only done things like this on actually firewalls and such - not sure you can even set something like this up on Windows 7. Do you have DHCP configured and such?
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/44137-vpn-problems/#findComment-578345
I havent touched the dhcp config at all. ill try messing around with that.
https://linustechtips.com/topic/44137-vpn-problems/#findComment-578480
Does Win7 have a routing and remote access service? This would be where you normally set this up on Windows Server...
https://linustechtips.com/topic/44137-vpn-problems/#findComment-578492
