I need a simple yes or no answer. I want to create an acces point using my new TP LINK router however I don't have a long enough Ethernet cable, can I use a power line kit to skip the cable.
By that I mean this > means connecte to
Router 1 > homeplug 1 > homeplug 2 > router 2 (AP)
I need the second router because the homeplug can't make a wifi signal just Ethernet
https://linustechtips.com/topic/441245-quick-help/
It would work. But there is the option to buy an wifi repeater.
https://linustechtips.com/topic/441245-quick-help/#findComment-5914183
I would need 4 wifi repeters to cover this distance
Thanks for the quick reply
If the distance is so long you need to make sure that they wall plugs are on the same electric circuit on the house. All though some powerline ethernet plugs can jump on different circuits.
https://linustechtips.com/topic/441245-quick-help/#findComment-5914203
I guess speedwise your better of with power line compared to a ton  of repeaters anyway.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/441245-quick-help/#findComment-5914262
