CPU Overheating?
Go to solution Solved by kameshss,
I'm not saying I want it to run near 100C normally, I'm just asking if this is a precaution my CPU has.
The cooler I have is an Asetek 550LC 120mm Liquid Cooling CPU Cooler - Extreme Cooling Performance (Single Standard 120MM Fan)
My Case fan is a Enermax TB Silence UCTB14 140mm Performance Cooling with Low Noise Profile Fan
Normally it would turn off if it were going to hit near 100 degree.
Hey guys, I purchased a new PC with an i7 5930K six-core @3.5ghz (overclocked to 4.2).
If my processor were to hit 100C, would it turn itself off or would it just die? Back in the old days, I remember CPUs just dying if they overheated but someone recently told me that they're programmed to shut off if they reach too high of a temp.
Guide to GTX 900 Series: http://linustechtips.com/main/topic/457526-nvidia-900-series-basic-performance-guide/
Performance expert, building noob.
There is no such thing as excess in hardware.
https://linustechtips.com/topic/441160-cpu-overheating/
Yeah that's not a safe temp, what CPU cooler do you use? It might be seated incorrectly or thermal paste applied in a wrong way
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/441160-cpu-overheating/#findComment-5913221
Nowadays most Hardware are programmed to turn off if they start overheating. Here is a list of software to monitor temps:https://youtu.be/mu-PRt_LbhM
CPU - i5-8400 , Motherboard - ASROCK Z370 Killer SLI, RAM - 2x8 GB DDR4 2400mhz , GPU - EVGA GTX 950 SC, Case - SilentiumPC PAX M70 Pure Black V2 Storage - 240GB SanDisk SSD, 1TB WD Blue, PSU - bequite! 600w Pure Power 10, Display - Dell P2417H, Cooling - bequiet! Pure Rock, Keyboard - Viper V730, Mouse - natec Genesis G55, Sound - Philips MCD712, OS - Windows 10 Professional 64-bit
https://linustechtips.com/topic/441160-cpu-overheating/#findComment-5913222
That temp is too high.
What CPU Cooler do you have?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/441160-cpu-overheating/#findComment-5913228
if your thermal monitor is on, is will downclock. don't let it get that hot. what kind of cooler do you have?
It would turn itself off at 96c. Doesn't mean it's a good idea to let it go that high. Stay below 80 if at all possible.
Hmm. Well redo your thermal paste and reseat the cooler. Failing that, upgrade the heatsink to something more powerful or consider watercooling it. The stock one is okay for general PC users, but overclocking isn't it's specialty.
https://linustechtips.com/topic/441160-cpu-overheating/#findComment-5913383
https://linustechtips.com/topic/441160-cpu-overheating/#findComment-5913405
