Do I need these cables?
Go to solution Solved by Oshino Shinobu,
The two smaller connectors are fan connectors. You connect fans in them to provide power.
The larger, middle cable, is a SATA power cable. It is plugged into HDDs and SSDs (some other things too) to provide power It is SATA power, but it is for the fan controller. You plug a SATA power cable from your PSU into that to provide power for the fan controller.
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5891190
You talking about the patent pending invisa-cables?
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5891200
@Kamilz15 there is no image. Also, follow your threads (button in the top right of the page) so you get notifications when people reply.
I see no cables there.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5891347
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5891368
So are the two fan connectors for the fan controller built in my case? I already have my case fans connected to the motherboard
They look like it, yes. You don't have to use them, but it will give you more control over the fans.
Note: Make sure you use the "quote" button at the bottom right of a post when replying to it. Otherwise people won't know you have replied.
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5891457
Thats a sata power, but you conect the PSU's sata power conector to that, to power fan controller
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5891547
Do you recommend doing it? The rest of my system is already built
It's up to you. It gives you more control over the fans, so you can make them run slower (so quieter) when you want. If you've already built everything, you may as well leave it for now, as it's not like the fans aren't working.
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5891743
I just plugged my fans into the fan controller so hopefully all will be good when I start my system for the first time!
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5892196
https://linustechtips.com/topic/439419-do-i-need-these-cables/#findComment-5892199
