Hey, Ive had this AMD R7 260X since 2014 and it has ran fine ive noticed that im getting lower FPS than usual. I only get higher FPS when when i reinstall the drivers. After i reboot i get lower FPS. Please Help!
specs: Intel core i5 4690k stock
           Asus ROG hero 7 1150
           8gb hyperx fury RAM
           R7260x Using AMD Catalyst driver 15.7.1 also stock
           EVGA 600b
           seagate barracuda 350gb
https://linustechtips.com/topic/438262-low-fps/
Why do you have a $200+ motherboard and that graphics card...?  :mellow:
What's your temperatures and gpu usage during gaming? Probably might want to watch your core clock, if it's not sitting where it should then your performance may suffer.
https://linustechtips.com/topic/438262-low-fps/#findComment-5875353
           8gb hyperx fury RAM
           EVGA 600b
Are you running mantle or DX11 games? I've noticed some problems with mantle.
https://linustechtips.com/topic/438262-low-fps/#findComment-5875384
and a 350 gb hdd with a $200 mobo
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/438262-low-fps/#findComment-5875439
Im upgrading little by little that why i have that GPU and hard drive. The temps of my GPU are around 50 degrees Celsius and The GPU usage is at 100% After Burner says that my CPUs first core is 762 degrees i dont know if that a error by the program or thats really my temps
https://linustechtips.com/topic/438262-low-fps/#findComment-5875589
If your core were actually at 762C your computer would be on fire right now. Are you sure that's core temperature or core clock?
https://linustechtips.com/topic/438262-low-fps/#findComment-5875667
