I was thinking about using a GoPro+mount.
Are there any other solutions you might want to recommend? I was checking this out, looks pretty decent.
Need thoughts and opinions on dashcams.
My Best 2013 Bitfenix Prodigy Build  Case: Bitfenix Prodigy White | Motherboard: ASRock Z77E-ITX | CPU: Intel i7 3770k | CPU Cooler: H100i | GPU: GTX 690
Fan Controller: Bitfenix Recon | Ram: Patriot IEM 16GB @ 1600mhz | Primary Storage: 2 x Samsung 840 Pro 256GB | Backup Drives: 2 x Seagate Barracuda 2TB | PSU: Seasonic X850
https://linustechtips.com/topic/43747-best-dashcam-solution/
As said before, you can use a GoPro for other appilcations. A GoPro will also produce higher quality video, wider angles with certain lenses, etc. Also, if you don't have much storage space for your GoPro to use, you can set lower resolutions to record more footage.
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572439
the new gopro Hero 3 shoots 1440p and is only $400 :D
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572456
Ya go for a GoPro.
Edit. What will you be doing with it? As in what will you be recording from your dash?
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572457
But even the cheap hero 3 is amazing.
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572461
Remember to think about the battery life. If I remember corretly the GoPro3 lasts for like 1½ hour.
HD3b firmware HD3.03.01.09
no bacpac wifi off 2.7k30T PT ON cam raw video test 1h14m.25s 23.4GB
Batt Bacpac wifi off 2.7k30T PT ON cam raw video test 1h49m.43s 35.9GB
LCD bacpac wifi off 2.7k30T PT ON cam raw video test 0h56m.50s 17.9GB
Batt Bacpac wifi off 1080p30n pt off video+photo @ 5 sec 3h18m.27s 27.8GB + 2,379 photos 867MB
no bacpac wifi off 1080p30n pt off video+photo @ 5 sec 1h56m.32s 23.4GB + 1,377 photos 368MB
LCD bacpac wifi off 1080p30n pt off video+photo @5 sec 1h18m.55s 11.0GB + 944 photos 297MB
no bacpac WiFi On 1080p30w pt off video test 1h28m.44s 12.4GB
no bacpac wifi off 1080p30w pt off video test 1h33m.35s 13.1GB
no bacpac wifi off 1080p30Tw PT ON video test 1h31m.18s 22.3GB
Batt Bacpac WiFi On 1080p30w pt off video test 2h37m.35s 22.1GB
no bacpac wifi off 1080p60w pt off video test 1h10m.47s 14.8GB
no bacpac wifi off 1080p60m pt off video test 1h10m.59s 14.9GB
no bacpac wifi off 1080p60n pt off video test 1h22m.59s 17.9GB
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572471
what do you intend to do with the dashcam? gopro if you are capturing racing but for a daily user or to have to capture those lol moments on the road like those russian dashcam vids then buy a mediocre $50-$100 dedicated dashcam from ebay or something. the more expensive ones only add weird functions like gps speed and enhanced night capabilities.
a gopro would be tedious to set up every day and bait for your car to get broken into if you left it in
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572479
At 720p 60 fps I get about 5 hours.
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572483
why not just get a bog standard 1080p wide angle camera..its a freaking dash cam not a movie camera he wants.......spend like $100-200 max and get something with a lot of battery life or can be charged form your ciggarette lighter.....lots of spce to record to and can produce clear images preferably at 1080p, 720p minimum.....the one you suggested in your post looks fine...
-Anubikai
| i5-4670k at stock until I do a custom WC loop | H80i | Asus Matrix Platinum 7970 at stock until I do a custom WC loop  | MSI Z87 GD65 | 1TB CAVIAR BLACK | 250gb Blue Scorpio | HX750 80 PLUS GOLD modular | 16GB INTEL EXTREME EDITION PATRIOT 1866MHZ | Coolermaster Storm Enforcer with two Red 20cm fans intake and exhaust |
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572493
-Anubikai
+1 to this!
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572541
-Anubikai
This is a viable option, but for what it's worth, a GoPro can be charged through a cigarette charger. You can also find an older GoPro (Hero 1/2 generation) for around $200.
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572560
He could get this for $200
http://gopro.com/cameras/hd-hero3-white-edition
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572565
that says £200.....thats equal to $300...
-Anubikai
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572661
-Anubikai
Oh on the US page it says $199 that is how much I payed for mine!
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572683
The GoPro 3 looks pretty sweet!
Coolermaster Scout 2 Case / ASROCK 990FX Extreme3 Motherboard / AMD FX 8350 8 Core CPU (Stock Speed) / Corsair H100i CPU Cooler / Gigabyte GeForce GTX 1060 WindForce OC 6GB / 16GB Corsair Vengeance 1600MHz CMZ8GX3M2A1600C8
Build Log: http://linustechtips.com/main/topic/20323-scout-2-update-build-fx8350-h100i/#entry244058
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572715
lucky XD i dont like uk prices, they suck ballz compared to the american prices for the exact same tech =( i want the nexus 7 2013 32gb and its gonna be $370 in the uk, dont know if thats more or less than america prices =/
-Anubikai
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572784
-Anubikai
$269.99 here, 0-7.5% sales tax to add if bought from store, but no taxes added if bought online.  :D
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572796
-Anubikai
$229 in the US I feel bad for you bro...And I see how lucky I am yo get tek at a good price!
Edit it is $269 sorry
And sorry for getting off topic :(
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572801
$269.99 here, 0-15% sales tax to add if bought from store, but no taxes added if bought online.  :D
okay now im sad.... :( whats worse is that i can even get it until september 13 2013.....AAAAAAAAAAAAAAAAHHHHH!!!
-Anubikai
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572803
I paid just under £1000 for my pc......use that amount and you can build something way better in america than what i built...its the stupid 20% vat that screws lots of people over.....also sorry if i made this thread a bit offtopic.....seems to have been answered though.
-Anubikai
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572817
-Anubikai
20% is absurd. If our sales tax was 20%, chaos would ensue.
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572825
Just a dashcam to record traffic and "lol" moments. I'd appreciate it if you guys would attach links. I dont thin a GoPro would have enough battery. Wouldnt I have to charge everytime I get in my car? Thanks for all the contributions to this post btw.
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-572909
there is this...11h left its at $30...bid on it....it uses old nokia bl-5c batteres to poer it so you can buy a crapton for real cheap...they are also rechargeable and last a long time
http://www.ebay.com/itm/Night-Vision-IR-Dash-Cam-Camera-2-5-LCD-Car-HD-DVR-Recorder-270-swivel-1080p-/231029332779?pt=US_Surveillance_Digital_Video_Recorders_Cards&hash=item35ca6bdb2b
or this....dual cameras....
http://www.ebay.com/itm/2-7-TFT-LCD-Dual-Camera-Rotated-Lens-Car-DVR-Vehicle-Video-Recorder-Dash-Cam-/400540720304?pt=LH_DefaultDomain_0&hash=item5d42165cb0
-Anubikai
https://linustechtips.com/topic/43747-best-dashcam-solution/#findComment-573040
