i think the audio on your mobo is better wait wut, yamaha sound card? its probably good then. (yamaha makes great audio products in general so i would assume the soundcard is better)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/437204-old-sound-card/#findComment-5860705
Test it and see?
probably not, but slide it into your pc and test if it still has drivers, and if yes, if it still makes a decent sound.
if it does, you have an extra microphone in / speaker out.
Couldn't get drivers. :( I tried the Yamaha XP Drivers and someone's Win 7 DIY drivers, it didn't work
https://linustechtips.com/topic/437204-old-sound-card/#findComment-5860867
