Reset a surface pro 3
Go to solution Solved by Volbet,
Yes, it is running W10. Do i need to buy a new copy of windows to do that? Or does it carry the license over if i reset through windows?
No need for a new licens. You are just using the new media to repair the old installation, so it will keep the licens intact.
Hi all,
I got a new surface pro 3 the other day - absolutely loving it, but I've been having some problems with programs not uninstalling properly. It gives me an error, and won't uninstall fully. It doesn't show up in the all apps menu, but when I try to reinstall, which normally fixes the problem, it says it's already installed! Help! Here comes my next problem - I figure a wipe of all the devices data would fix it, but when I go to reset, it asks me to insert installation media! It's a laptop of course, and I don't have a copy of Windows handy, let alone a key to activate said install media... Suggestions?
Thanks
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/
Is the Surface running Windows 10?
Becuase if it is, them you can use another computer to create the Windows media on a disk or a USB driver.
You just create the media with the Windows Media Creattion tool.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5860638
Hi all,
You need to make recovery media
however there is a built in recovery system, you could try that  - its a windows refresh
http://windows.microsoft.com/en-gb/windows-10/refresh-is-part-of-reset-in-windows-10
I had a Surface Pro 3.
worst $999 i ever spent in my life.
Why? they are great (also not helpful haha)
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5860698
Bought: Sept 3rd 2014
WiFi Stopped Working: Sept 27th 2014
Overheating Issues (would not boot): 2 weeks after
Kick stand no longer strong enough to support SP3: 3 months later
And the whole time, Microsoft refused to replace it, even under warranty and when it was a documented issue. Microsoft Support is a joke and I'm never buying a Surface or Windows Phone device again in my life.
Honestly my biggest spending regret ever. Coming from the guy typing this away on a $1300 Macbook 12inch 2015.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5860742
SNIP
Strange, not heard of many issues, I have friends with them that swear by them, still a shitty experience which is a shame - dont understand the stand issue, we had one in store that was hammered by customers and no issues after standing around since before launch (its still there now as is the SP2 which is still there haha)
hey i love the 12" macbook so.. I have nothing to say there
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5860765
If you google around, the WiFi and Heat issues are super common, especially on the i7 versions. There is a 200+ page thread on the Surface forums about it.
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5860770
there are 200+ page problem threads of on every product :P but ah that sucks
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5860779
Do you receive a code 2503 or 2502 while uninstalling s/w ?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5860785
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5874041
https://linustechtips.com/topic/437199-reset-a-surface-pro-3/#findComment-5877253
