Final Build, need help with cooler and PSU
Solved by Electro_XD,
PCPartPicker part list: http://pcpartpicker.com/p/MryDHx
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($239.99 @ Amazon)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler ($49.99 @ Amazon)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard ($158.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR4-2400 Memory ($54.99 @ Adorama)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($89.99 @ Amazon)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card ($344.98 @ Newegg)
Case: NZXT Phantom 530 (White) ATX Full Tower Case ($122.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ NCIX US)
Total: $1161.91
I've changed the PSU to a 750W 80+ Gold certified fully modular EVGA PSU, which will give you clean power and some headroom for some future upgrade. I've also changed the case to a NZXT Phantom 530 (White) which looks pretty good and it gives enough space for you GPU. For the Cooler I've went for the Phanteks' PH-TC12DX_BK 68.5 CFM CPU Cooler, I've read some reviews of it and it says it's a beast for overclocking cooling, so you should be fine with that, also, it's in black and white which will fit your build perfectly. For the RAM, I have gave it a little upgrade from DDR4 - 2133 to DDR4 - 2400 which is a bit faster and it looks better IMO with the silver/black color.
If you have any questions, DM me or reply to this message
