I dont have an ethernet cable in my room so im guessing i need a dual band pci express adapter,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704133&nm_mc=KNC-MSNSearch&cm_mmc=KNC-MSNSearch-_-pla-_-Network+-+Wireless+Adapters-_-33704133
Is this product ok to buy? should i get a different product? is this information correct?
heres my build if you need it for compatibility reasons, all info is welcomed
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($341.98 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($25.99 @ Newegg)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($153.98 @ Newegg)
Memory: Corsair Vengeance 8GB (1 x 8GB) DDR3-1866 Memory  ($54.99 @ Newegg)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($333.98 @ Newegg)
Case: Thermaltake Level 10 GT Snow Edition ATX Full Tower Case  ($159.99 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($61.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($21.98 @ Newegg)
https://linustechtips.com/topic/436310-wireless-adapter/
Get an EVGA PSU.  That adapter is good.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/436310-wireless-adapter/#findComment-5848666
Good adapter I have one myself but don't get a CX PSU, get dual stick 4GB RAM and if you're only using the build for gaming you don't need a i7 just get a i5
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/436310-wireless-adapter/#findComment-5848673
