hi im sorry for i keep posting dumb threads just wondering would the x6 1055t be ok for 480p streaming and will it bottleneck hd 7950
http://www.ebay.com.au/itm/130937810190?ssPageName=STRK...
and im just wondering will it last me till steamroller next year
what do u guys think
amd fx 6300  @4.4ghz @1.4/ga-970a-ud3/HD78702gb /antec 620w psu
https://linustechtips.com/topic/43622-x6-1055t/
The 1055T may bottleneck a 7950 a little bit, but nothing bad. Also, yes it is okay for 480p streaming. And yes, it likely will.
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570222
anyway i will be overclocking the cpu and with my cooling nh-d14
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570228
It might but a bit, i had a 680 with a 1090T and i was very happ so yeah, depending on the game you might do more than 480p streaming
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570230
may i ask did u oc ur 1090t
i had it for a while at 4GHz but my H80 wasnt really up for it since at 4GHz temps would go to 61C and the max safe temp for that cpu is 62C, i wasnt too comfortable
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570247
well i have a nh-d14 for my cooler with my mobo will it be ok ga-ma770t-ud3p
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570254
well depends how much Voltage your chip needs for the frequency you want, your ambient temperature anda ll that, but it should be okay for 4GHz i think.
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570262
ok cool so a hd 7950 or gtx 760 which one is better for 1080p gaming
If you overclock card, 7950. If you dont OC GPU and you like PhysX etc. (all Nvidia marketing stuff), get 760. They are very close.
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570302
well i have no idea how to oc a gpu and im scared to do it im currently using a hd 6950 1gb and im just wondering which one runs cooler
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570327
GTX 760 with some aftermarket cooling solution (Gigabyte Windforce/Evga ACX Superclocked/Asus DirectCUII - pick one you like the look the most cuz they will perform nearly equally)
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570392
spend a little bit more and get a black edition if you havent bought it already, Id personally go for a fx6300 though.
like the x6 1100t
and i found this one ati-7950-3gb-powercolor-pcie-video-card-
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570444
yup, or a 1090t
the 7950 is great, i dont have any experience with powercolor though.
or this one http://www.gumtree.com.au/s-ad/gosnells/components/14x-7950-s-5x-barebones-rigs-650-to-1-1k-/1023915340
https://linustechtips.com/topic/43622-x6-1055t/#findComment-570642
You should be fine, overclock your CPU and then everything from then on will fly.
My PC specs; Processor: Intel i5 2500K @4.6GHz, Graphics card: Sapphire AMD R9 Nano 4GB DD Overclocked @1050MHz Core and 550 MHz Memory. Hard Drives: 500GB Seagate Barracuda 7200 RPM, 2TB Western Digital Green Drive, Motherboard: Asus P8Z77-V , Power Supply: OCZ ZS series 750W 80+ Bronze certified, Case: NZXT S340, Memory: Corsair Vengance series Ram, Dual Channel kit @ 1866 Mhz, 10-11-10-30 Timings, 4x4 GB DIMMs. Cooler: CoolerMaster Seidon 240V
https://linustechtips.com/topic/43622-x6-1055t/#findComment-575367
It will last you easily ^_^ when console optimisations hit Phenoms are actually going to have 0 bottleneck
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
https://linustechtips.com/topic/43622-x6-1055t/#findComment-575378
