GTX 960 fan problem?
Go to solution Solved by JerkyMcDilerino,
The fan keeps stopping on me unless I have EVGA's precision tool up and running. Otherwise it runs fine. Any idea?
It's not a fan problem, it just a feature that all 3rd parties NVIDIA introduce something call " 0db fan" that allow fans to turn itself off if the GPU temp is safe. But it kick in like around 45% when the GPU temperature reach 65C - 66C.
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/435725-gtx-960-fan-problem/
does it have the no fan running on idle thing
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/435725-gtx-960-fan-problem/#findComment-5840318
Nope. Have it set based off of temp; anything above 20C should be running the fan.
https://linustechtips.com/topic/435725-gtx-960-fan-problem/#findComment-5840464
It probably has the idle fan thing on. Put it under load and wait and see if the fans spin up.
Got to 51C and didn't kick in.
https://linustechtips.com/topic/435725-gtx-960-fan-problem/#findComment-5840465
https://linustechtips.com/topic/435725-gtx-960-fan-problem/#findComment-5840538
Hmm... Get it to like 60C or 70C. Don't let it go over 80C though, that's starting to reach the limits.
I generally have open hardware monitor open when playing so I can see it at all times.
https://linustechtips.com/topic/435725-gtx-960-fan-problem/#findComment-5840543
Well, I know for a fact that the 0dB fan mode is what you're talking about. Open both and once the card hits over 60C-65C the fans will kick on.
https://linustechtips.com/topic/435725-gtx-960-fan-problem/#findComment-5840956
