I am looking for a high quality multi port (preferably 5) USB charger with at least 2 amp per port that works in the UK. Open to all suggestions but preferably below $100 or £60, and available on amazon - If it not on amazon please suggest it anyway.
http://www.aliexpress.com/item/AB0100-ORICO-RH6CS-5-port-USB-3-0-HUB-for-Smart-PC-with-2-BC-1/32272110135.html
CPU: Intel i7 8700k    MB: Gigabyte Z390    RAM: Corsair Vengeance 16GB     GPU: GTX 1070 Ti 8GB
https://linustechtips.com/topic/435645-best-multi-item-charger/#findComment-5839026
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/435645-best-multi-item-charger/#findComment-5839028
Pretty much anything from Anker.
https://linustechtips.com/topic/435645-best-multi-item-charger/#findComment-5839080
My AMD Build:
FX 6300 @ 4.8GHz, Zalman CNPS14X, MSI 970 Gaming, 16gb 1866MHz AData Ram, 3D Club R9 280X, Corsair 600M Psu, Thermaltake V3 AMD Edition Case, D-link 1200AC WiFi, 240gb Mushkin SSD, 2tb WD HDD, 140gb WD HDD (recording gameplay), 5x CoolerMaster SickleFlow 120mm fans, Windows 10 64Bit
Sisters Intel Build:
I7 4790k @ 4.4GHz, CoolerMaster 212 Evo, Gigabyte Gaming 5, 16gb 1866MHz Corsair Ram, 3D Club R9 390, EVGA 650GS Psu, NZXT S340 Case, D-Link 1200AC WiFi Card, HyperX 240gb SSD, 2tb WD HDD, Windows 10 64 Bit
https://linustechtips.com/topic/435645-best-multi-item-charger/#findComment-5839705
